A
Anonymous
Guest
You must enter a message when posting
Then why is it illegal to sell non-compliant tooling, especially as a machinery/tooling dealer even to an amateur or sole trader? In the event of an accident you may find that your insurers don't actually agree with you on this point and decide on a "partial liability" claim. But then perhaps I'm viewing this from the perspective of a former employer where a risk assessment was a legal and insurance requirement (and still is with my current insurer). Personally I don't see why anybody in the trade should be allowed out of this one as the risk is the same self-employed or "cards in".......Mr_Grimsdale":3fynv2cs said:It's not illegal for me as a sole trader to use non-compliant tooling ASFAIK and in any case I couldn't afford to do otherwise.
The "machine made" cutters you are talking about are generally produced from a hand made template used on a manual profile grinder - if the template is right, then the tooling will be, too, as I'm sure many (ex-)engineers on here would agree. If owned in-house the profile grinder can be used to "tweak" a cutter set in the same way as doing it by hand, but is likely to be more consistent if the template is corrected.Mr_Grimsdale":3fynv2cs said:Machine copied cutters are never quite as accurate as hand made ones suprising though this may seem. The explanation for this being that hand making involves repeated "offering up" to the profile sample to be copied, until no error is perceptible.
But that is why if the base template is right to start with then this "adjustment" shouldn't be necessary. If you're having to do that then surely there's something wrong with the template you're working from.Mr_Grimsdale":3fynv2cs said:Machine made copies could be fettled up in the same way, but safety blocks with pegs, limiters etc inhibit fine adjustment.
I think you'll find that router cutter designers take this into account - compare a 2in diameter 2-flute with a 1/2in 2-flute and you should be able to discern some difference in angle, but even of that weren't the case the router cutter does take a much smaller "bite" out of the work by dint of it's higher rotational speed. 2-flute @ 18,000 rpm = 36,000 cuts/min (router cutter) against 3-flute @3,000 rpm = 9,000 cuts/min (shaper head on saw). That translates to a much higher number of cuts per inch (25mm) assuming a feed speed of 1 metre/min (40 in/min): 900 for the router, just 225 for the saw spindle. Which is going to appear or feel smoother? Failing to take feed rate into the equation means that you miss what I feel is a significant factor.Inspector":2xthh0at said:The resulting surface from the moulding head will probably be better, especially in the wilder grained woods, because the 'cut arc' is larger (effective lower cutting angle) which produces a cleaner cut.
The principle can be observed by using a 1/2" diameter bearing guided pattern bit and a 1" or larger diameter one, and comparing the results of the two.
In reality this isn't a choice that you can make. Spindle moulder profile blocks are generally between 75mm (3in) and 125mm (5in) in diameter. I normally choose the largest head you can and run it at a lower rotation speed simply because of the extra smoothness you get from the bigger heads due to their inertia, just like the wheels on a bandsaw (the flywheel effect). A solid steel 125mm diameter block running a 50mm high cutter weighs quite a bit more than a 75mm one and consequently requires a bigger motor to drive it, bigger bearings and a bigger brake to stop it. Incidentally the smaller 75mm ally blocks have come in mainly to accommodate the weaker braking on lightweight spindle moulders.Inspector":2xthh0at said:On a shaper given the choice between a 4" cutter or an 8" diameter one, which would you pick to produce the best finish?
Oh, yes, I know how easy it is to burn HSS and tool steel. But the heyday was surely pre-1980. Since the 1970s big routers have become steadily better whilst carbide tooling has become cheaper. It has to be remembered that the Germans more or less invented carbide tipped (Widia = wie Diamant) tooling to cope with their WWII wondermaterial, Spannplat or chipboard, and although TC was initially a military product (designed to tip anti-tank projectiles fired from aircraft such as the Ju-87G Stuka), TCT tooling appeared in woodworking in the UK as early as 1950 (source: Wadkin catalogue) - and we were relatively late adopters here due to the need to import tips. TCT tooling has therefore been around for a long time and has become steadily cheaper, certainly since the late 1970s probably because of the improvement of grinding techniqes more than anything else. Here in Europe I remember deWalt selling the 3-wing moulding heads for their radial arm saws, indeed I had one, but the inherrent lower rigidity of the radial arm saw and consequent vibrations made it a very poor substitute for either the spindle moulder or the router and now I'd think twice about a design which periodically could eject cutters (the securing bolts could occassionally loosen or shear which is possibly why DW sold a substantial steel guard to go with them). I'm sure the modern cutters have a wedge-lock design which means that this is not possible, but they are still as awkward to guard as a dado head (Oh darn it! I went and used the G-wordInspector":2xthh0at said:You need to remember that in the heyday of the moulding head, there were few large routers and only carbon and high speed steel bits available. I'm certain that you can still remember how easy it was to dull a high speed steel router bit. That left it for the table saw /radial arm saw to do the heavier moulding and shaping operations for the hobbyist and small shop that couldn't afford a shaper.
