Greeting fellow 'woodies'
I've had a Kity table saw for a good few years and I have always thought the space underneath was wasted so this weekend I 'knocked up' a new base with room for plenty of storage
Its only made from scraps and offcuts of ply and 'caber' floor, no fancy joinery just loads of glue & screws.
Now I must confess that in the past I have been a bad boy & removed my crown guard especially when cutting big boards and it was while cutting the chipboard for this project that I finally decided to do something about it.
The first thing I have done is to seal the base of the saw and fit a 4" outlet on the back (I took the saw to pieces and did a few mods inside as suggested in another post )
Next I trawled the net for ideas of overhead crown guards and came up with my own interpretation of the Axminster one but at Zero cost
The main arm is from an old vacuum cleaner attached to a metal bar via an aerial bracket. The plastic is lexan from an old propagator (I hope SHMBO doesn't read this :shock: ) superglued and screwed. The rest is just bits of wood and metal. The hood stays in any position thanks to spring washers and 'ny-lock' nuts.
I have given it a test with some MDF and I am very happy with the dust extraction and feel a lot safer with the blade covered.
I am not too happy with the aerial bracket holding the arm (any suggestions ?)
If you look closely at the fist pic I moved the on / off switch up near the sliding carriage (where I can see it !) which I thought would be much safer than fumbling around below,
and it is ........until you come to cut a large board and then the board covers the switch (homer) DOH so I am planning to mount the switch on the main arm and fit an extra emergency stop button at knee height.
Next step is to make drawers and doors, I'll keep you posted.
