I have finally got the saw connected up - v v longstory. Anyway got a 16A supply fitted and a 16A MCB. But it keeps tripping. Does the MCB need to be 20A? Bit confused as others on here havevthe same setup but no issues?
misterfish":i1wqk6d5 said:Type C is designed for this sort of equipment with an initial power surge caused by the induction motor starting. My Wadkin kept causing a type b to keep tripping - replaced with a type c and it works fine. Many others have also had the same problem and fitted a type c.
Misterfish
Fulhamtim":kwm5t6mv said:Unfortunately they are not the sort of thing you can slip past the "boss". I am after a jointer/planer. And not sure how to approach that one.
Fulhamtim":2n4vf0o3 said:The rail is 158cm, with a 15cm overhang to the right and a 5cm overhang to the left.
