Eshmiel
Another thread has had an orthogonal jaunt into the matter of woodworking flatness and precision. It needs a new thread for those of us who enjoy exploring the far end of various pharts.
One view is that woodworking flatness is that which the eye can detect and no more. Another view is that this is a limited definition albeit prevalent - some surfaces need to be flatter than that; and others don't really need to be flat in their detail as long as they're flat across a whole surface. There are no doubt several other kinds of WW flatness sought by we woodworkers.
Then there's other kinds of precision, such as that required for various kinds of joints; or for stress-bearing architecture of furniture. And for the tools used in making stuff.
* When you make a piece of furniture, what degree of flatness, joint quality and other precision-of-surfaces do you aim for?
* Does your required-precision vary with the item being made and, if so, in response to what attributes or functions of that item?
* What degree of precision do you want in your various tools and how do you ensure it?
Personally I tolerate "marks of the maker" lack of precision but feel I've been inadequate if an item somehow looks "wonked" or "bodged" in surface, joint, proportion or general appearance. I also prefer tools to have a degree of precision that can approach the ability to make changes down at the 0.1mm or 3-4 thou level. Sometimes this makes it necessary to make the tool parts themselves precise to less than those values. A plane sole and blade that can take off just one thou, for instance, is often a requirement because it enables the plane to more easily improve surface qualities and the precision of joints.
What about you?
What about you?
