CHJ":op0or1ag said:I suspect the small tubes have sucked sufficient air back in the tube before replacing the cap to activate the contents.
CHJ":3g5dbz1v said:My experience has been that the bottles deteriorate more rapidly as the contents reduce, 3/4 full will stay usable considerably longer than one with 10% of contents left.
I deliberately deform my bottles before sealing to reduce the air gap. (Oval or Flat Packaging is handier for this than round bottles)
bugbear":23hmxr0h said:Hmm. One wonders why the manufacturers (who presumably understand the chemistry of their products quite well) moved from tubes to bottles.
BugBear
CHJ":2aladz2y said:bugbear":2aladz2y said:Hmm. One wonders why the manufacturers (who presumably understand the chemistry of their products quite well) moved from tubes to bottles.
BugBear
Nothing wrong with Bottles, it's totally dependant upon usage rates, hence why it is normally packaged in 20, 50 or 100gram. quantities.
My normal usage makes 50gram packages viable with little wastage.
