Stop chamfers on a router table/ spindle moulder.
Trevanion":17hm31kr said:
..... I had assumed from the title you were looking for a solution for either.......
Yes, sorry, my mistake.
I have a solution involving a simply jig and a cutter with a bearing guide at the bottom. However, I've decided that my ballusters need to be 30/ 32mm square, rather than the 25 square that I'd allowed for, so until I've machined up some new stock tomorrow I won't be able to put it to the test.
Use a mortar bit, 45 degrees with a flat bottom, hold the stock in a jig at 45 degrees. Square shoulders.
Sent from my SM-G960F using Tapatalk
Here's what I did:
I think that's pretty self-explanatory. Thanks for the suggestions and help. I've now done all 40 ballusters.
Nice work! Looking forward to seeing the completed staircase!
That's some quite wild looking oak too.
Trevanion":1s2o07a6 said:
......That's some quite wild looking oak too.
It's from all sorts of off cuts and bits and pieces I've had kicking around the workshop for years. I had bought some inch boards for the ballusters, but decided I wanted them to be around 30mm square instead, hence the scrounging. It was quite a lot of work reducing odd shapes and sizes to 30mm square.
