Thought I would add to this thread, as I have recently noticed several people claiming success with steam bending kiln dried timber. Whilst I have done a bit of steam bending greenwood for chairmaking, often the limiting factor is sourcing green or air dried material and that seems to dissuade a lot of people from trying. So when no less a person than
Peter Galbert says he is a converted to the practicality of steam bending kiln dried, I took notice though it seems he is holding his insights for his new video series. He did share on Instagram that he was bending kiln dries ash without a strap into double bent Windsor chair arms with "5 days soaking in the rough, then shaved , steamed for 2 1/2 hours "..... and an added advantage is that the resulting part dries much quicker than if it had been green to start with.
Another internet woodworker Philp Morley (@philipmorleyfurniture on instagram) details
here his success (after much failure!) bending 2.125”x2.125” kiln dried walnut and says:
Here are several things that made this possible and these were the things I picked up from several people.
1 presoak the wood.
2 buy the Lee Valley strap thingy.
3 use shrink wrap.
4 get lots of steam.
5 don’t give up.
Look around the internet some more seems to offer the following:
1. Presoaking - 5-7 days seems to be the usual recommendation. Some Americans seem to be big on adding a couple of cup fulls of Downy fabric conditioner (which I believe is the same as Lenor) which acts as a surfactant and 'softens the fibres' or maybe just helps the water to penetrate ( veneer softeners contain surfactants like glycerine for similar reasons). My understanding is that water is good at absorbing and conducting the heat so getting some back into your timber will help even though is will only penetrate a little way.
2. Bending Straps - Basically wood is much stronger in compression than tension, therefore whilst not always essential, success rates are higher if you use one as it stops the outside of the bent wood being put into tension. Whilst you can source 16g or 18g stainless steel strip, I have had success with builders band (
from screwfix). Wooden blocks and thin wedges are cheaper and simpler than
adjustable end stops. The main thing is to ensure you have a strap that will not stretch and your timber fits tightly between solid end stops
3. Shrink wrap - this was a new one on me. Watching Philips video, you do see that when he cuts away the wrap after bending the wet wood surface quickly dries. So I assume by restricting water evaporation it helps retain the heat for longer.
4. Lots of steam - the old rule of thumb is 1hr for each inch of thickness, but it looks like kiln dried wood needs a lot longer, presumably because the dry core will conduct heat much slower than green wood at 20% moisture. Peter above was saying 2 1/2 hours for something that looks less than an inch. As others have said it is the heat that counts, so a meat or oven thermometer to confirm your steam box is at around 100C is a good check. I imagine over steaming is much less of an issue with dry wood. I have found one
2kw wallpaper stripper quite sufficient, though for big stuff I have had to refill from the kettle
5. Don't give up - True, trial and error plays it's part on the journey. My early tries were spoilt by hurrying. It is important to allow the wood to bend gradually so a strong steady force is best - you can manage without large levers or winches however these encourage/force you to apply the bend gradually in a controlled manner.
Finally I encourage anyone to experiment as it is a great process (when it works). There is a zero waste movement in sewing, designing patterns and approaches that minimise the wastage of material. Whilst wood does grow on trees, these days we need to make the most of a precious resource and see less of our lovely expensive wood end up in the vacuum extractor. Steam bending is such a process and once you have it makes laminating look such a waste.
