Managed to break a lot of wood trying to steam bend and also tried the hot pipe dry method but without success. But now I have a system which works very well, so if the following helps anyone with similar problems, that's good.
Firstly, the timber I like to bend is NZ Rimu, a conifer which I understand is not ideally suited to steam bending. I am trying to bend the last 10cm of 60cm long planks, 2.8mm thick and tapering over the last 10cm from 7mm wide down to 3mm wide.
The first issue was with the steam box which wafted steam over the timber ok but thought it would be better if a bit pressurised so welded up a new steamer out of some offcuts of schedule 40 pipe. This is easily done in a variety of ways to suit what material you have available but you need to make sure that you have some sort of pressure release on it. You want a steamer, not a bomb.
In 15 minutes the timber was pretty bendy but was getting cracking on the convex side of the curve. The wood fibres on the concave side of the curve compressed without problems.
The problem appeared to be with my little bending jig.
A & B are bits of 9mm plywood. The steamed timber C is placed between A & B which are then clamped together. I think clamping like this places stresses on the wood causing cracks.
The solution was this:
B is the same bit of 9mm plywood, A is a strip of 0.6mm X 9mm wide stainless steel cut from the back panel of an old microwave from the box of stuff that you have no use for but are too loathe to throw away. Put B into the vice, jam the bit of steamed timber C up there between A & B and with a pair of pliers pull A tight and slowly down and clamp it all together.
It would seem that applying pressure simultaneously over the whole length causes cracking whereas applying pressure sequentially avoids this.
Works for me.
