• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale Startrite TA 145 Table Saw 240v.
Distinterior
8 Mar 2014
Colchester, Essex.
Refurbished Startrite TA145 saw. Dates from the early 70's. A good solid, heavy saw.
It was originally a 3 phase saw when I got it but I fitted an original model 240 volt motor that I had, along with an original online starter with NVR and motor overload protection.
New bearings fitted in the motor and the spindle. 2 new drive belts fitted. It also has the Louvred side panel ( these are often missing). It also has it's original riving knife, blade guard and cast iron fence with micro adjustment.
All adjustments work sweetly and this is ready for another 50 years of work....
A couple of battle scars on the cast iron top, but it doesn't affect the saw in use.
Price....£500.
Collection from Colchester, Essex.
I have some questions.
How much does it weigh?
Does this run off a standard 13amp plug socket now?
What's the blade bore?
Is there any kind of dust extraction port or is it "a broom and dustpan" ?
What are the dimensions of the top? (in mm preferably :) )
Any possibility of delivery? (Diss area)
1. = 90kg.
2. = Yes.
3. = 5/8" ( 230mm dia blade with 80mm max depth of cut)
4. = No dust extraction unfortunately....
5. = 585mm wide x 560mm deep.
6. = I do have a van and could possibly deliver the saw to Diss if we come to an arrangement....
Sorry somethings come up, If it's still available next month I may be back.
This is still available and needs a new home!
I forgot to state in my original post.....This has an induction motor!
I can possibly deliver this saw to a new owner within a reasonable distance, if it helps....?
Final bump before this gets advertised elsewhere......I'm still open to a reasonable offer and can deliver within a reasonable distance for diesel money....
The 900W is a bit misleading as it's the rated "output" of the motor......Most modern day saws only state the input wattage which obviously is going to be higher......The motors on these Startrite saws certainly have plenty enough power for their cutting capacity.
Hi ScaredyCat,
Apologies for the late reply.
No, I still have the saw!
I've been so busy with work over the past couple of months, that it is still sitting in my workshop at home at present.....☺
I've been meaning to put it on Ebay, but just never got around to it.....
Are you still interested in the saw...?
Hi ScaredyCat,
Hi, I’d like to buy it if its still available
Hi Sebb,
Unfortunately, the saw is technically sold to ScaredyCat and it is just a matter of when we can arrange for delivery.
If, for any reason, the situation changes, I will let you know.
Tim.
Edit. You have a PM Sebb!
