sploo
Somewhat extinguished member
I've just taken delivery of an old Startrite 275 table saw and I'm trying to work out some of the threads used on the machine. I'd guess it dates from the early/mid 1980s; given that it has the straight blade height and tilt adjustment bars (each with two handles), rather than handwheels.
On the top of the fence there is a set of tapped holes, and I'm pretty sure they're 3/8" 16 TPI. Whether it's BSW or UNC I'm not sure.
The side of the fence has two smaller tapped holes (for attaching a sacrificial wood fence). A 1/4" 20 TPI UNC screw is too large/coarse, so I'm not sure what that one is.
Finally, the round bars on which the fence runs have female threads (to attach the "stick mike" bar extensions). It looks to be around 12mm, but definitely isn't M12. On the left end of the front rail there's a male thread, which I don't think is original (it looks as though someone's screwed in a bit of threaded rod). It appears to be around 14 TPI (thread pitch of 1.825mm). That could be a red herring, and maybe someone's jammed some random bit of rod into one end at some point, as I can't get it to come out.
So - could any knowledgeable soul give a child of the metric age some hints as to which set of hog's heads, fathoms, and ounces they used for the threads on this saw?
