I have been trying to tune my stanley no4. I could not
get decent shavings from maple. I just started toying with wood
a half year ago and have been getting all the info from internet.
I learned that for harder woods a higher cutting angle is better. So
I gave my blade a backbevel of 15 degrees. Tried it again and the results
were better, but I could not get long, wide shavings.
Tried to tune the frog. Flattened the sole, still not perfect, but much better
than before.
Tried tuning the chipbreaker. I noticed the chips would get stuck between the blade and the chipbreaker. Now there is no gap between the two. I also polished the upper side of the chip breaker.
The result is now much better. I can get very thin(fragile?) shaving and thicker(stronger) shavings.
I don't have much space, so therefore I am using this little work bench that won't sit still(it will lift) when I am planing. That makes planing very difficult.
I am glad with the result.
Ali
than before.
Ali
