A
Anonymous
Guest
Hi All,
We are restoring/renovating our house which is getting on for 300 years old and the next project is to replace the treads and risers on the staircase. As i have never done this before i am hoping that someone can give me some advice.
We are not sure if these treads are original to the house but by the wear on the centres of each tread you can see that they have been there for a very long time, because the edges are still about 1 1/2 inches thick yet the middle has been worn down to just over a 1/4 of an inch.
The stairs have one stringer attached to the wall and on the opposite side the balistaires are morticed into the treads. Is this an open stringer?
The hand rail and the balistaries are in good condition (we want to keep as much of the original parts as we can), as is the stringer.
Am i right in thinking that i can just remove the hand rail, balistairs, treads and risers (not the stringer). Then after morticing the hole for the balistairs, glue new treads and risers into the stringer?
A couple of things that are worrying me are, after looking under the stairs i noticed that there were no triangled glue blocks attached to the backs of the treads and risers. Yet i am sure that i heard somewhere that you have to install these to strengthen the stairs.
Also again looking under the stairs i noticed that the bottom of the risers are attached to the back of each tread. Is this correct? because i thought that the back of the tread would be housed in the bottom of the riser or the bottom of the riser would sit on the top of the tread, again to give the stairs strenght when any body walked on it.
I know that because a staircase is classed as structural you need planning permission to alter or install a new one, but would i need permission just to repair one?
Is this a job for a novice?
Finally the risers on these stairs are made from some sort of softwood. Can i replace them with ply? If so what thickness do you think i should use. The treads will be redwood.
Any other tips would be great.
Mike.ca
Mike.ca
