YorkshireMartin
Hello all.
Back again with another question, but hopefully one that is general enough to be of use to other people too.
I'm happy with the accuracy of my combination square. It's a starrett model and having checked it against a couple of different engineers square, i'd say it's pretty much dead on.
I'm wondering what level of squareness is acceptable in cabinet making and how to measure the margin of error. Obviously, we'd all like to get everything absolutely perfect every time, but occasionally things happen and there may be a slight problem affecting squareness, maybe a stray woodchip when thicknessing, things of that nature.
My particular problem relates to the cutting of a 100mmx50mm section of walnut. It was planed square but during use of the track saw to cut it in half lengthways, in the denser grain, I've suffered some blade deflection which has pushed the cut out of square. It's enough to see daylight under the combi square, but I'd say no more than about 0.25mm between the ruler and the surface of the wood at the worst point. The two pieces are at final dimension.
Should I just get on with the job, or scrap it and start over to achieve perfection?
What would a cabinet/fine furniture maker do if faced with this?
Many thanks.
Many thanks.
