Spraying MDF
I bought the Erbauer one about a month ago. I had a load of Tongue and Groove MRMDF to paint. I started with a brush but getting into the grooves was a pita so I whizzed down to Screwfix and bout the Erbauer. I was using Cuprinol outdoor wood paint and had to thin it a bit but it seemed to work very well. I've not sprayed before so can't judge it against anything but I was happy with the result. I had to do a couple of coats but I was trying to build up thin layers and avoid runs. It did use up a lot of paint compared to a brush or roller but the paint had to go somewhere so I assume I'll probably have more protection on my walls.
This is what I sprayed and the result:
I was pretty pleased with the Erbauer. I couldn't find fault with it, but as I said I've not used other systems to compare it to.
    203.7 KB
    246.3 KB
