For Spraying walls and render stay away from compressor setup you will struggle to get the paint out.
Use something like a Fuji 5 or even compressor and gun for banister or even door frames and door but you won’t be able to do walls.
At your budget consider getting a Graco GX21ff second hand they pop up ever so often on market place or eBay.
the GX21ff has got the power of the GX21 but with a hopper and also two different hose size one for walls and one for doors and skirt.
you don’t want to load up the hose full of paint which you ain’t going to use plus it allows less product to come through so more control.
If you get a cheap gx21 then might worth
The handheld graco that Peter Millard uses is meant for touch up or small areas like skirting board and door frames usage and not for full cabinet coverage. Hence why the pumps always failed.
i looked into Wagner 350 but noticed a lot of people had issues and there were not as robust as the graco unless you go into there SF range but then it’s £££.
