Resurrected once before, and hoping to do it again, but it is the best article on spraying MDF I’ve found on the web (and the best finish). I’m looking to spray MDF and having read around and got a lot from this post, I was hoping for a bit of further guidance on getting the same finish achieved by Richard. Sorry for such a direct list of questions but all the kit seems to add up and I’m trying to ensure I don’t spend money on the wrong things.
1.) I see Morrells White Primer 8005/641 (Waterbourne) was suggested, but wondered if there would be a reason for this to be better than the 8004/400 Basecoat?
2.) Also, when using the Morrells 362 Severe Use Waterbourne Lacquer, will any of the sheen rates work the same, or is there a sheen rate you suggest (Ideally I’m after a mid sheen, but finish quality is most important)?
3.) Would it be suggested to always use the clear 90% after, or will the 2nd coat of the 362 lacquer be enough (and still tough)?
4.) I’ve got a friend who has two new Devilbiss GTi Pro guns to sell and was wondering if anyone could advise which would be better. One is a Devilbiss GTi Pro H1B-12 (which I think is HVLP) and the other a Devilbiss GTi Pro T1B-13 (which I think is their Trans Tech). Assuming one would be right, any idea which would be best?
5.) Finally, any guidance on a compressor/turbine for the spray gun? I’m not sure the difference. I saw spraygunsdirect have a compressor for about £200.
Thanks in advance for any time. I can always post some pics on the forum after.
