spirit stains
blue
New member
25 Feb 2009
hi can anyone advise me how to use these stains has i have tryed but cant seem to get the desired effect,as when you put on a colour and then put on another it seems to remove the colour beneath.
i am trying to get a marble effect with a dark blue and light blue on a turned vase i have produced. thanks for your help
Well if it can be done with stains I'd be interested to learn about it, marbling effects are normally achieved with paint... and I've never tried it so I can't offer help on that one.
well if its a tight grained timber it is possible. Use the lighter stain first, with a teaspoon of blonde or white FP. Once touch dry give it a light , and I mean LIGHT de-nibbing with , say 400 flour or SC paper.
Then with a "marbling"sponge go over it with the darker stain.Once dry coat with the same polish used earlier.
De-nib again and coat with an acrylic varnish to keep the vase "bright "in colour and display to all.
hope this helps,
HS
thanks for that i will give it a try,its good to know there is help just a message away.
Hi Blue.
Normally when using spirit stains on turning you really need the right surface to get the effect. ie - The wood must have the grain effects already there to be effective. The stain won't do it on its own.
If you want the marble effect you would use the wood from a branch crotch of a Sycamore, Birch, or Horse Chestnut. All pale woods, and being crotch wood will have the swirling twisted grain effect of the triple junction. Once you have prepared the surface, you go over it with say a dark blue stain. Then sand it back until you are removing some of the stained covering. Usually this would come off from the harder sections of the grain structure.
Then you could use say a mid green around the bared areas. Just stippling it on with a cloth pad. Sand it again gently this time, and you could then use yellow on any pale areas. When finished it sometimes helps to blend in the edges of the stain areas using a cloth dampened with thinners. Then you can seal with oil or spray lacquer.
As said already if you want a imitation marble, the only real way to my knowledge is using paints and sponges. You should be able to find out about this in any DIY store that deals with decorating materials.
