Spiral up cutters
jasonB":3nroub6f said:
The spot weld remover only has a cutting edge on the tip not the sides, it would be like using a twist drill in a router :shock:
Jason
Ok, I accept that Jason, just thought that if it was HSS the Lands might be sharp enough.
Actually chas it does say milling as well, I just looked at the heading, and was going by what I know of spot weld removing drills. Does not actually say what metal it is but HSS is quite likely.
The throw away three flute end millsare also worth thinking about.
Jason
Stick to the imperial ones unless you have a 6mm collet to fit the shank :!:
J
J
I have Imperial and Metric collets for my routers. The result of purchasing in UK and Germany.
