CaptainBarnacles":22bwg44f said:
it took me a while to realise I should just cut out the bulk of the waste on the table saw then just go through the moulder for the final dimensioning.
Not only was that much quicker, it required fewer changes of underwear and I was left with a load of quarter sawn oak strips that I can use as glazing bars etc.
To do that you must have removed both the riving knife and crown guard from the saw and probably worked American style, i.e., guardless. Now, whilst it's not illegal for an amateur to remove those safety devices and undertake the task in that manner, it is illegal for us professionals unless we comply with HSE regulations for alternative guarding.
Generally I discourage everyone, including amateurs, from working without guards on the table saw as this is an American practice and US H&S regs for table saw usage are very different to UK regs, and US style usage doesn't comply with UK regs. Anyway, be that as it may, I'm not going to bang on about how you shouldn't operate a saw unguarded, because I don't know for sure if that's the case, but there is a better option than using the table saw for creating those beads, which is a perfectly acceptable and safe way of working -- you simply buy a groover for your spindle moulder. Fit the groover, fit the Shaw guards, and away to go with an excellent measure of safety.
Groovers such as the one at this link are suitable, assuming you can buy one to fit your machine, which I suspect is highly likely:
http://www.wealdentool.com/acatalog/Onl ... m_869.html
You can also get all sorts of spindle moulder tooling from a range of people. Probably one of the most common suppliers for both amateurs and many professionals are Axminster. Here's what should be a link to their spindle moulder tooling page:
http://www.axminster.co.uk/spindle-moul ... rc=froogle
I suppose I should close with a strong suggestion that you do sign up for some training, preferably with someone that's a qualified wood machinist. I don't wish to be disparaging, but self taught woodworkers (both professional and amateur) are frequently a real menace around some of the more technically challenging woodworking machines, and spindle moulders fall into the "very challenging" category. I've seen far too many self taught woodworkers undertaking very poorly set up and therefore dangerous wood machining operations, with the saddest part being they had no idea just how much danger they'd put themselves in. Slainte.
