I've made a few oak Windows and doors for an old chapel, I have a Sedgwick SM4 ii single phase and a Multico tenoner. I wish I have bought the 3 headed Sedgwick tenoner which would have been a better option IMO. The spindle moulder has a sliding table and a power feed. The spindle is about 5.5HP and can cut the rebates in one hit without any issues, however I'm not running the Maggi at full tilt because I can't load and unload it in my own at that speed so I've never tried it flat out.
Like already said, I've found a rebate block, cill block, exandable groover, universal cutter block and a selection of cutters to be all that is required for a one man shop efficient production of Windows and doors. A decent Morticer is a must IMO.
I think if you combine your tooling budget and machine budget you will get a really decent setup as well as the separate blocks you need which will be far more useful for virtually everything you are likely to make. Once the tenoner (scribed tenons), spindle for the mouldings and Morticer are setup you can along with something to cross cut (I use a Wadkin RAS) which doesn't take me very long at all, about 30mins to set all machines from scratch - I know I'm slow compared to many) you can knock doors and windows out extremely quickly as their is no breakdown setup to do.
