Spanner
antifoul2020
5 Aug 2021
Scotland
How many mm is 1/2W as far as I know it’s the same size as a scaffolding spanner
But I need an open ender for taking the wire brush off my grinder
Cheap adjustable spanners are horrible, get a nice Bahco one with extra slim jaws - accurate fit and handy for sliding into tight spaces.
Or just buy an open 1/2whitworth - plenty still around. Try a boot sale or on-line.
If you picked up 300 scaffold fittings today, you would be lucky to find just one with 1/2" Whitworth nuts on it.
Only very old fittings have 1/2" Whitworth. The vast majority are 7/16" Whitworth, or 21mm.
Thus, the only scaffold _spanner_ you would see today with 1/2" Whitworth is the large end of a double-ended one (https://www.hss.com/buy/p/spanners-scaffolding-double-ended). As the OP does not specifically say that it is the large end on a two-ended scaffold spanner that is required, any single-ended scaffold spanner picked up at random today will not be 1/2" Whitworth.
Rather than guessing, cut a slot 21mm wide into an old pizza box. If it fits the nut, that is the size. If not, cut a wider slot and try again.
I use the spindle lock and an old motorbike glove, sort of crack the thing rather than a slow pull and they come loose. Stout gardening glove would do it too.
Short of that a 24mm spanner will do it, sloppy fit yes but it's only cracking loose a wire brush or wheel.
Always described with derision as "plumbers tools" where I worked. Not sure what they had against plumbers :)
Yes yes a sharp whack with your gloved hand in the direction of spin should loosen it. I have a wire cup brush and it even works with that.
WO Bentley would sack a mechanic on the spot if they were caught with an adjustable spanner in their kit.
Quite right too !
I can remember one lad where someone picked the offending article out of his toolbox, held between thumb and forefinger. "What the hell is this? What are you, a mechanic or a fu**ing plumber?".
At which point it was carried at arms length across the workshop and dropped in the bin.
Being a youth who knew no better I hastily hid mine at the bottom of my box!
I have several but only really used for bending and twisting type jobs when fabricating stuff. A good sized one is brilliant for bending bits of plate or bar.
Proper spanner is much better for anything involving an actual nut, even plumbing :)
