custard
I'm a full time furniture maker, but only a very occasional turner. A couple of sessions per year making drawer pulls, the occasional turned furniture component, and that's about it. So I'm very familiar with woodworking and sharpening, but a complete ignoramus on all matters turnery!
Anyhow, a couple of questions.
Can someone explain what are the differences and benefits (if any) between a continental style spindle gouge and a traditional spindle gouge?
Does anyone use a basic (ie non-fingernail) grind on a spindle gouge? If so how do you prevent it fouling the work piece?
And my final question relates to sharpening turning gouges with the Sorby ProEdge.
Take the Sorby Continental Style Spindle Gouge as an example, as far as I can determine the closest setting to reproduce the original factory grind is the 35 degree extension and the basic Sorby/Tormek fingernail jig (as opposed to the long fingernail jig). But that means the jig is almost bumping against the ferrule,
These are the settings on the jig,
I've had this ProEdge a fair few years, these earlier jigs were adjustable, but I believe the latest versions are locked in a specific position. As far as I know (but I'm not 100% sure) this is the original position and should therefore correspond to the current locked position.
This is the grind it delivers...but only for another half dozen sharpens, because then it'll collide with the ferrule!
Surely this can't be right, what am I missing here?
