Kittyhawk
These are models 57 and 58 respectively and the first ones built for pleasure. This is not to say that the preceeding 56 weren't fun but the two Camels were built unordered and because I wanted to have a shot at a WW1 aeroplane because of a couple of construction issues. The first was the use of annealed beer can aluminium to replicate the alloy parts of the plane and the second issue was how to make the wing struts and undercarriage strong enough - accomplished by drilling the bits lengthwise and inserting a 1mm diameter stainless rod which also goes into the wings and fuselage.
This may not be necessary if the model is to sit on a shelf someplace but the intention with all my models is that they should be able to withstand a bit of robust handling and be played with if the recipient so desires. I do. Sometimes I like to hold a model in each hand and run through the house making engine and machine gun noises, especially on a Friday when it's my wife's turn to host the weekly get together of the local ladies contract bridge club. This is helpful in enhancing my whispered reputation as a loony eccentric and it gives the affronted bridge club ladies something to gossip about on the way home. You have to find a bit of fun where you can.
One of the Camels has been sold but I don't mind if the other one hangs around at home for a while. I like the look of these early aeroplanes, they have something of steampunk look to them and I like to try a couple more.
