RogerS
devonwoody":23rhk193 said:OK Roger the first one, strength, has a green line all the way across which I assume is 100%, because there is no other table to look at and quality is quoted as high verbally.
You can't make that assumption. Unless it specifically says it in the manual then High could just as easily refer to signal strength.
Question - can you see the channels that I have listed on your TV ?
