MrJay
<3
dennis":1s7xbclr said:Pekka
You say that you had a slight problem where the skirtings met the architraves you could have used plinth blocks which are made slightly higher and thicker than the skirting and can either be plain or moulded, it is an easy way and even plain ones can look quite effective but as you like doing things the hard way you probably preferred your way and the whole job looks good.
