Hi all
At work we're doing a re-furb of an old granite farmhouse. We saved all the old rafters which are oregon pine (a.k.a douglas fir) and we intend to use them to make a load of internal window cills. The depth (from window to front nosing) of the cills will be around 400mm which is about the thickness of the granite walls. The boards have been planed/thicknesses to about 24mm and they look really lovely. Each one is is around 160mm wide and so three will be edge jointed together to get the 400mm needed.
My question is about how to keep the cills flat and how to limit the effects of cupping and shrinkage. My boss's suggestion is to glue and screw the whole cill to some 18mm plywood. I'm not sure about this idea though as how will the wood be able to shrink/expand? But then what about veneered plywood which is the same thing surely - wood glued to plywood.
What about screwing the cills to the ply with fixed holes at the back of the cill (where it meets the window) and then have elongated holes in the middle and at the front of the cill. This will allow the pine cill to expand contract as it wishes.
Anyone else got some suggestions? Will it work to glue the whole thing to ply.
All the best,
Andrew
All the best,
Andrew
