woodbrains":1b8l5cxg said:Hello,
MDF is wood bits (very small, granted) glued together and then, perhaps veneered. Anything can be called solid wood if you are going to stretch the definition.
But then I suppose furniture made in workshops where everything is done with 4 siders, Brookman machines, hydraulic presses, wood welders, and spindles, panel saws set on programmable DRO's, painted with HVLP spray, claiming to be hand made, then I suppose you can't complain.
Mike.
woodbrains":3dtodjp1 said:But then I suppose furniture made in workshops where everything is done with 4 siders, Brookman machines, hydraulic presses, wood welders, and spindles, panel saws set on programmable DRO's, painted with HVLP spray, claiming to be hand made, then I suppose you can't complain.
Mike.
Ttrees":28z9xku7 said:I'm thinking hide glue would be the most suitable of glues for this application ... What do you think ?
