Bodgers":w2ni4zcs said:
... the best way to not end up with a wood movement disaster on these things further down the line.
The door itself will be made out of approx 17-18mm thick Oak stock. Strips 50-60mm wide laminated together. Each door (2 per cab) approx 900mm by 350mm. The strips will run vertically, with the grain.
I've made doors with a similar appearance out of solid material, but mostly using wood with smaller expansion and contraction characteristics than the oak you're proposing, e.g., American mahogany. A solution I've used more than once are reinforcing braces fitted across the grain with a sliding dovetail - see below: somewhere I have a photograph of a similar construction, but I can't locate it, so a two minute sketch will have to do. Make the housing in the panel longer than the dovetail on the brace to allow for expansion and contraction, slide the brace in dry, and about 25 - 30 mm before it's pushed completely home, apply a little glue to the still exposed end of the dovetail to lock it in place.
The edge of the panel showing the exposed dovetail becomes the hinged side, and you'll need to allow a gap for expansion and contraction of the door panel. As others have said, quarter (radially) sawn oak has smaller cross grain expansion/ contraction characteristics than tangentially sawn material (5.3% radial and 8.9% tangential). You ought to allow up to 1.5 to 2 mm for seasonal shrinkage and expansion (between roughly 13% MC [summer] and 8% MC [winter]) of each 350 mm wide panel using tangentially sawn wood, and about half that for radially sawn. Slainte.
