woodbloke66
Following on from the Plane Handling thread (topic120735-15.html) a light hearted look at what's actually in my Star Trek mug (which was purloined from my son when he was about 8...he's now 32) :
As you can see, it's pretty full up but what's in it?
First and foremost, several strips of ebony, rosewood and bog oak (I think) which are useful to keep the sole...
..of your favourite plane(s) off the bench. The Norris panel plane is an old friend and no longer used by the way, but if you want it, you'll need to grovel to the bank manager :lol: :lol:
Laid out on the bench I have, from left to right....
Exotic strips of wood - already discussed
Small paint brush - useful for applying glue to dovetails
Stipple brush - used with hot water for removing glue squeeze out
Bamboo BarBQ skewer - useful for point application of tiny amounts of glue and mixing epoxy
'Sharpie' permanent marker - used for highlighting the honed bevel when grinding a blade on the Tormek
Red roller ball pen - used to mark out dimension lines on working drawings
White pencil - for use on Ebony and Bog Oak
4H pencils - used mostly for marking out when I can't be ar&ed to use a knife
Carpenter's pencil - for rough marking out and face edge/side marks
Black biro (fine point) - fantastic for marking out dovetails...try it and see!
Perpsex glue getter offerers - bits of perspex shaped on the disc sander into knife blade profiles etc which are ideal to get into corners
So....what's in your Star Trek mug? - Rob
