Snipe with no known way to fix - Axminster AP260SPT
ddcboyle
New member
10 Dec 2024
Whitburn, Scotland
Hi guys, need help with snipe from my new tool. Just bought an Axminster AP260SPT planer thicknesser, which I upgraded from the Dewalt DW733.
I constantly get snipe when using the thicknesser part. Its a cast iron table, no infeed table on it so I don't know how best to adjust it to stop snipe. It does have an outfeed table support, but the snipe im getting is from the infeed.
The wood is flat, fed flat (and ive tried adjusting the feed angle of the wood) to no avail.
Im planing about 150 shelves that are 10mm thicknx 50cm x 6cm. Constantly get snipe. I got snipe when I was planing 20mm thick boards aswell.
The dewalt had the adjustable infeed table, so I have no snipe at all. Surely at 2.5k, I should be able to plane on this with no snipe. Any ideas?
(Photos attached to all the parts of the thicknesser incase theres any adjustments)
    1.7 MB
    1.1 MB
    1.5 MB
    1.3 MB
    1.1 MB
Snipe at the start can be caused by the feed roller pressure being too high but if the planer is new I would contact Axminster before fiddling with it.
When thicknessing if you feed the next piece of wood in straight after the one before it so there is always wood in contact with both rollers it can reduce snipe but unless someone is helping it can be quite tricky, especially with short pieces!
Think.
There's no spring between the thickness table and the cutterblock. There shouldn't be any movement in that height.
If the machine is stiff and you have already planed one side of the board truly flat which becomes the bottom surface, then if the wood is fed in flat and kept flat, there shouldn't be snipe when you thickness.
Be pedantic about it and check :
You have locked the thickness table so it can't tilt as stock passes through.
There's no snipe at the ends of the lower face of the board from your planing operation to throw off the thicknessing ?
You have roller supports on the infeed and the outfeed sides to ensure the stock is fed absolutely flat in and out of the thickness table ? Check with a straightedge, maybe a long spirit level because they are straight and stiff. Don't rely on the plank itself to show you where flat is, the plank can droop. Place the inward roller at a distance a bit over half the plank length away from the table so it's all stable without you holding it. Outfeed side it has to be near enough that the plank will be starting to droop but will hit high enough to ride up and over the roller. Far enough that the overhanging plank won't be seesawing on it and trying to lift the final end towards the cutterblock once it's free of the infeed roller and being held down only by the outfeed roller.
Is there anything in the manual for your planer that gives setup instructions for the spring tension on the in and outfeed rollers ? If there is, check this. If there isn't, message and ask Axminster how it should be set. I think that's about the only thing that can make a real difference if you are feeding flat in and out.
You don't feed in and out at an angle (above or below horizontal).
The feed rollers are quite high presure but fairly close together.
Planing a decent size, long plank, there's a lot of weight acting at quite a few feet away from the machine. It's a lot of leverage that just one of the two feed feed rollers has to overcome for a few inches at the end of each pass. Cranking up the feed roller pressure should help keep the timber down but increases friction against the table, and if you properly support the timber in and out, the feed rollers shouldn't have much to do.
I had the same problem with infeed snipe. I reduced the pressure on both feed rollers, gave the table a good coat of wax and snipe was gone. It took some back and forth to get the pressure right, as too little pressure caused the boards to slip on the rollers and made gouges where the board stopped moving. But keep at it, you can get it right.
I found that having longer in feed and out feed tables helped , As the board was entering the in feed roller it was flat and well supported , Then through the cutter block working towards the out feed roller , At this point if the board is not fully supported the weight will cause the board to tip causing snipe , At my previous home I built it into a work bench so I had a 1 meter wooden table aligned with the steel P/T table and the same on the out feed side, It did work but took up a lot of room , I did consider using the roller type stands that could be folded and stored when not in use.
Thankyou for the replies guys. All had mentioned the spring tension.
In my head, I thought - if the first roller has too much tension, surely its better as it will force the wood down flat. But still snipe
So... what I think is happening is;
Theres too much pressure on the first roller, thats causing the actual bed to push down. (The cast iron bed has the centre post which is for raising and lowering, but has a rear strut design, which flexes). I think the rear strut is pushing down, causing the table to tilt downwards at the entry point, because of the pressure roller1 is putting down. Because its pulling the table down, that in turn would cause the wood to enter at an angle, until it hits roller 2 where the feed equals.
Makes sense to me, but yet to test it. I have managed to get it to a point where there is still snipe, but not too much, so i can deal with it for what i need to get through for christmas orders, then ill go back, readjust and hopefully that fixes :)
I presume from what im explaining, that would make sense that that would cause snipe? I.e. reduce roller1 tension a bit at a time until no castiron table push down at entry point.Just before i miss something.
Yes makes sense. On the lunchbox style thicknessers the rollers are part of the head that also holds the cutter block, with too much roller pressure the head if lifted then drops down, causing snipe, this is just the reverse of what you are experiencing.
Snipe has a huge amount of variability in it's depth. My thicknesser normally does not give any but occasionally, especially with thin boards, I do see some. I can see it when I hold the board to a raking light and I can also feel it with my fingertips, however a light sand and it is gone. I've also seen videos where snipe is a noticeable step which would be impossible to remove with a little sanding. I would say the former would be 'acceptable', but if you are getting the latter due to table flex/movement on a new machine I would be in contact with the manufacturer and likely heading for a refund.
Me again. Snipe is the nature of the beast. The configuration of the rollers wants to create snipe. As I mentioned above, it is trial and error but I got mine to work. Plenty of wax on the bed is essential and should be used regularly. I had to cut 1 1/2 coils off the rollers springs to get it where I wanted it.
I think that is exactly what is happening, I used to have a Axminster PT (different model to yours) and you could sometimes see the thicknesser table tilting slightly forwards and then backwards as the timber passed through.
Not a great solution, but my parkside model is very seldom used, hence the cheap option.
I just cut everything a foot longer than I need and then cut off the snipe.
I do feel that if you spend over £1,000 for anything, you should expect it to work satisfactorily out of the box or at least after simple calibration. Snipe should not be accepted from a machine designed to give you precisely finished product. Send it back.
I have never understood the recommended height of the blades to be above the bed its snipe waiting to happen, never had snipe setting the blade level with the bed using a piece of plate glass.
To be honest, I feel exactly the same way....I recently bought 3 x new blades/knives for my Hammer A3 31 and thought I would check the height of the new blades ( although, in theory, they shouldn't need adjusting as they fit back in the exact same position as the old ones were as they are reversible, disposable knives....)
I tried setting them up as per the common method of the blade moving a pencil about 6mm......I found this created snipe when planning......I then adjusted all 3 knives down to, as accurate as I could tell, flush with the out feed table.....It now works fine!...👍
As you feed the timber into the machine, put a couple of fingers under the material as it gets drawn in and apply upward pressure. You'll find the snipe ought to disappear; very old machinists trick - Rob
