Hornbeam
Yes but a Clifton 5 1/2 is a chocolate hobnobTo me, the Stanley/Bailey plane is the equivalent of the chocolate digestive biscuit, in that both are impossible to improve upon.
Well must have Baileys as it is the Xmas Season!!!No need for any further mention of Baileys.
Those are the same machines I have. I’ve used my Jack to rough prep would and then run through planer thicknesser. Is this what you do?
Right, if no joiner or too wide for the jointer then sure. I just went all way in and got 410 mm wide planer/thicknesser or jointer/planer… or jointer/thicknesser
I've been very happy with the manufacturing accuracy of the Veritas planes I bought. (mostly in the US about eight years ago)
Fine Tools in Germany tend to be price competitive versus the UK and seem to have most Veritas planes in stock and to be actually discounting them at present. Some of the smoothers are currently out of stock however...
The good makers do an incredible job I think. I'm amazed that they can make a profit given the extent of the product ranges they offer - both Veritas and Lie Nielsen. The higher end Eastern stuff is coming on strong too in the case of the more standard types.
I hope we're not heading into a price war like that which destroyed tool quality post WW2..
There is a lot of potential for problems to develop in even a genuinely capable plane manufacturing process. Fixtures have to be carefully designed and kept clean by those using them so that the (irregular) casting is supported and rigidly held during machining but without being sprung, and machine tools have to be consistently capable of accuracy. Then there's the matter of the aging of the casting - stress relieving may or may not be 100% reliable leading to some distortion over time.
Less sophisticated jobbing shop methods (i.e. operator and machine with less by way of fixtures, high accuracy CNC etc) processes (up to the point where it becomes impossible due to worn machine tools, fixtures etc) rely heavily on the skill and commitment of those doing the machining to deliver the goods - and on the management culture.
An authoritarian but technically incapable management (e.g. accounting or sales led) that drives output rather than the requiremnent to 'get it right first time' risks staff finding creative ways to get product together and out the door without much regard for precision or what matters when the tool is in use. (perhaps the case with my previously discussed oldish Clifton no. 5?)
Operatives (as opposed to machinists) hired recently off the street and placed in such an operation are likely to be especially risky - and unlikely to have any appreciation of what the consequences for the end user of their shortcuts will be.
DIY rectification of e.g. sole flatness problems must mess up lots of planes too - sandpaper on even a flat surface is not always very precise. Perhaps for rough work if the paper is glued down.
Best then though to switch to a purpose made granite surface plate (not expensive in smaller sizes these days) or other proven flat surface. Wipe on a thin film of engineers blue
(not the marking blue which dries to enable visibility when marking out with a scriber) then drop the plane sole on to it. (fully assembled with the usual lever cap tension, the frog locked down but with the iron retracted)
Mislaignments or out of flat bearing surfaces on the frog and/or the frog bed in the sole should be sorted out first.
Selectively remove material from the areas which made contact (to which the blue transferred) using a proven truly flat diamond plate like an Atoma and repeat (usually numerous times) until getting contact over most of the area and especially in front of the mouth and at the nose - and at the rear end.
Once flat the finish on the sole can be improved using finer diamond plates and carefully and frequently flattened (the Atoma plate again) successively finer hand held waterstones. Shapton are good because they wear less than some.
Be very careful if holding the plane in a vise - a quickly made wooden fixture is safer. More than minimal pressure (especially if applied further up the unsupported sides) risks springing the casting - but too little and your plane could end up on the floor.
It's tempting to use a fine cutting file for coarse metal removal, and it is possible - but an awful lot of care is needed if irrecoverable hollows are not to be produced.
Blue used like this on a reference surface is a quick means of just checking for flatness too, but be aware that a granite surface plate is flat to within a couple of tenths of a thou so that with a fine film of blue it will make even a very flat plane sole look bad by contacting it only in places.
Hand work with a carbide scraper is also an option for metal removal, but requires skill and is risky around the mouth.
A ground cast iron or even heavy duty extruded aluminium machine table may function as a decent reference surface - but beware of the fact that the tables on many even supposedly professional quality machines are not even close to flat. (even on jointers where a few thou in the wrong place can be disastrous) Most rules are not truly straight either.
The blue wipes off easily with solvent and a rag - but between the blue and the iron dust in water its a messy business.
It's hard to do much work of this sort without a flatness reference - a small granite surface plate and reference straight edge is a good investment for anybody likely to be doing this sort of thing on an ongoing basis... e.g. but lots offer them: Surface Plates Granite
Some of what has been mentioned by Vaj is in this video.
For me personally I view the steps in the video as a waste of time. I did something similar once, you might even find it here on the forum.
Once you get into planes a bit you learn what areas are important and what are faffing about.
That’s some machine you’ve got there!Right, if no joiner or too wide for the jointer then sure. I just went all way in and got 410 mm wide planer/thicknesser or jointer/planer… or jointer/thicknesser
Just shy of £500 for a LN smoother. I don’t care how good they are, £500 is a rip off.the other thing that's a little odd in the current environment - I make the comment above with the thought that I would from time to time clean up planes for someone local who was serious about woodworking at no cost. Not an unlimited number, but a core group, to include flatness. It's tedious until you know how to do it well.
It used to always be easy to say "just go buy a premium plane" but production of everything in the US is so far behind that it's not as easy.
and as much as I'd like to say "you have about a 20% chance from a small sample of getting a plane that's going to cause you a lot of extra work, so if you can't ______, send it back and request a check on the sole of the plane"
____ would generally be plane two edges that match without having gaps at the end.
...as much as I'd like to say that, I doubt most beginners would have any idea if they're planing the ends off or the mechanics of the plane is making it difficult not to.
I hear that LN's prices are starting to go up significant on some items that only crept up slowly. Given that it took them a while to get bank approval for a business plan the last time they expanded, they probably needed to do that, anyway.
How do you propose the premium planes to measured, if you don't have two of meeting points at toe and heel?The *only* thing I've ever encountered on LN planes was the slight hollowness in spec on the sole. I've never had any issue with any other parts of the planes not fitting, and it's hard to say that what I don't like in the two planes concave is a quality issue - it's in spec. I don't think LN or their buyers would really understand why it would be better to set the constraint perhaps in an asymmetrical way (very little concavity tolerated, but a little more freedom on the convex side. I don't think the average buyer will use the planes enough to even notice. Of the planes I bought used, all were flat, but none had ever had the irons reground, even after years of possession).
