johnny
I have come across a large supply of 12mm OSB boards 1225 x 800mm
I am thinking about buying 20x or so for this project as Ply would be way too expensive and MDF not strong enough for this application as it needs to be self supporting from the edges like a shelf and carry modest loads . Mdf is also too susceptible to damp
The boards will need cutting to a rectangle which I'll do with my circular saw and then I'll need 6x shaped cutouts to the edges .The cut outs are symmetrical if you were to cut the board in half either vertically or horizontally the cutouts would overlap .
I cut out a prototype board with a jigsaw and it was tough going and difficult to maintain a decent shape to the cutouts . I tried using a thin jigsaw blade for all the curved cutouts but 12mm made it slow work or the blade would break
My question is without investing in an expensive bandsaw how would you advise going about this job using DIY hand tools . Would a router be a better option than a jigsaw to remove the cutouts ? I was thinking I could then construct a jig to lay over each board ?
How expensive might that be in router bits ? would I be better off making a template for my jigsaw ?
