pe2dave
Bosch GO 3 on order, thanks for the input.
I absolutely love my Bosch IXO 6th gen! It has LED light, it is compact enough to put in the pocket and you can also buy several attachments: I particularly use the cutter (to break down cardboard boxes) and right angle adaptor.
But the ergonomics of the reversing switch are insane.Take a look at the milwaukee
https://www.sgs-engineering.com/mil...n-drill-driver-with-interchangeable-heads-kit
This is really handy and if you are getting on a bit it is much lighter to use than the bigger makita drills / drivers which I only use for the jobs that need the extra power or the impact driver.
Yes it was odd compared to my Makita's with a slide switch but now I find I can still use a thumb to reverse direction although it took some geting used to. I would think if you have small hands and short thumbs then you will find the way I do it hard. If driving a lot of long timber screws then I find the makita's do have the edge on power and speed, the milwaukee will do one or two 6 inch but it drains the battery and soon struggles.But the ergonomics of the reversing switch are insane.
Compared to the Makita it is much more compact and lighter with the advantage that you can have a pilot drill in the chuck and a driver bit in the hex adapter and just swap them over easily, plus both the offset and angle adapters have been very useful. If making 20mm holes for an MFT it is also easier than the larger Makita as I find it more manageable and less top heavy.Not exactly small though, is it?
It would seem 'this product can't be shipped to your address' (UK).I absolutely love my Bosch IXO 6th gen! It has LED light, it is compact enough to put in the pocket and you can also buy several attachments: I particularly use the cutter (to break down cardboard boxes) and right angle adaptor.
https://www.amazon.co.uk/Bosch-Scre...86dc55035969e8ce791b47afb37&th=1&gad_source=1
For anyone else interested in a budget version - there's a lidl offer from Sunday for £15.
I'm going to buy this for the attachments alone!
https://www.lidl.co.uk/p/parkside-4v-cordless-multitool/p10015311
EDIT: Thanks JSW, who posted this earlier !
I can confirm the attachments also fit the previous PAS 4 D6 model.Just got the Lidl one today, not used it in anger, but the offset adapter is neat, and seems plenty powerful enough for what you'd expect on the few screws I've tried it on!
Cardboard cutter is quick too! LED light is nice and bright too.
I have used one of these around the house over several years. No drilling, but just a fantastic cordless screwdriver. Ergonomic and enough torque.
