The 'level' error is of no concequence as far as wood carving will be concerned, shows up with engraving simulation using the pen though, might even be an error in the wood support block the paper is stuck to.worn thumbs":2td8yvs3 said:Definitely progress! I had a similar situation with the packers I added to my router table, not a huge surprise and I knew I should have given the surface a very light skim as a first job.
Seeing it doing what it is designed to do, even when it's telling me where I've failed to give it accurate instructions is very satisfying.worn thumbs":2td8yvs3 said:Isn't it quite hypnotic watching the machine do what it is supposed to do?
