CHJ
As mentioned Elsewhere I've embarked on trying to put together a small CNC Router to use in combination with my turning bits.
It's going to be long job I suspect but it should stimulate the old grey cells a bit over the coming months.
Base and Side Panels are the key to the alignment of everything else so I chickened out and purchased them ready cut from the Designers Web Site
I've started on the finishing off of the Side Frames by sealing with sanding sealer prior to painting to keep out any moisture and look a little smarter.
And embarked on doing the same with the Base Board but decided to sort out the clamping fixing insert nuts before any sealing and finishing.
First a trial on a back position, (least noticeable if it goes wrong)
Then Drill out all the rest of the matrix and slightly countersink holes.
This is when you appreciate a basic Pillar drill with wide throat capability, not the best for precision engineering but a boon for sheet wood tasks.
I will use the Pillar Drill to inset the Insert Nuts to ensure they go in as true as possible just so they look neat.
Think I'm going to lip the edges of the Base to hide the Ply layers, just for the aesthetics, time is not going to be a limiting factor on this while I procure the bits and pieces.
