Sliding Mitre Saw - Rebate Cuts
If it's Germany no doubt they will. They like people to stick to the rules :)
Sent from my iPad using Tapatalk
Pink Freud":2ek3umxi said:
Wow :shock: ...so do they like, fine you or something?
It's much worse. There are no second offenders. :shock:
In my experience, even the better saws don't cut accurately, all due to the crappy mechanism they use which is always just a threaded rod that stops against a bit of flimsey metal. I'd suspect you could possibly get better results by beefing up the mechanism.
Can you show a picture of the kind of results you get? ... I have found that I can get decent enough results, which I can then pair with a chisel.
