I’m hoping that someone has a cunning solution to a problem I have. Just over a year ago, I remodelled a house I had bought, as part of it all the skirting and architraves were replaced. The skirting and architrave is MRMDF, and there is an awful lot of it. I had it installed and the house painted, that’s not blaming the chaps who did it, but I know some of the way it was installed wasn’t brilliant. Anyway, it’s in, it’s painted and carpets are all down. After a year, the underfloor heating keeping the house at a constant temperature everything has dried out and shrunk and might still be moving ….so far by 2 ~3 mm or c 1/16”. I had a load of cabinets made which were beautifully scribed and fitted to the walls, again made of MRMDF, painted. A similar size gap has appeared all around them to the walls / ceilings. Now, the cabinets I can simply re-caulk. Very irritating, time consuming with repaint the walls / ceilings. The skirtings however….well. I can’t think of a solution without ripping it out and a redo, and then I can’t guarantee it wont happen again. So I’d like a solution that doesn’t involve removing it. It’s amazing how rough it looks in the photo. In reality the finish isn’t too bad……I did a quick caulk to see what would happen after about 6 months ago, only rough……it expanded beyond the elastic limit of the caulk.
So, the skirting joints had been glued, but, clearly when something shrinks something has to give. The skirting was glued and pinned to the walls.
