Mark A":2ptloz2z said:
You would like to import a US saw, but you're not sure whether HSE will approve of it?
Regarding brakes: I doubt that is an issue because most circular saws are unbraked. Similarly, riving knives are often missing from saws so a worm drive's lack of one shouldn't be a problem.
Mark
Without meaning to be blasé i don't really care if they do or do not approve of the saw. For me personally it will see just as much use out of work as it would at work, but it would just make life so much easier at work!
I was merely offering the OP what could be an alternate route 'so to speak' with the worm drive essentially being a modified angle grinder (should he need it).
When you look at the very earliest worm drive Skilsaw's you can see they are quite literally a modified 10" grinder with a circular saw blade fitted and a base plate strapped on in what looks like a very adhoc manner!
It really looks to be the case that some bright spark over there just slapped on a wood blade to their grinder possibly to save money on tools, and some even brighter spark happened to walk past and watch the guy and thought "WTF... hmmm, Actually this guy might just be onto something here! :idea: "
You own one (i'm jealous atm) but you can see just from looking at it that it is built like a tank, it will out last every other power tool i do or will ever own.
IMHO From a safety aspect i can't really see anything that would be more dangerous than any other mains powered hand held circular saw available in the UK. From AvE's tear downs the only aspect that jumps out is the actual trigger switch which only appeared to be marked for use in US and CAN! Perhaps it is quite literally that switch is not deemed suitably insulated by the powers that be in Brussels [-( :duno:
I think the most dangerous part of that saw or any other (to quote AvE) is the '220lb Gorilla at the wheel' and tbh i think i've been using these types of tools for long enough now and have enough going on between my ears to be capable of operating it correctly and safely!
Eric The Viking":2ptloz2z said:
Sorry to persist with the thread drift but... is the DHS680Z 'S 3m rail the same as the one for the SP6000K? If so, your criticisms surprise me: I have one and I agree it is fragile, but it was around 1/2 the price of the Festool equivalent. I find mine far better than using connectors.
On the Skill saw - CE marking is to do with selling products not repairing them. Someone doesn't want your business...
Yes, it's exactly the same guide rail.
And yes mine is a 2 piece track, however i did buy 2 jointing bars and used one in both the top and bottom channel which made it really solid at the joint.
Yep scary delicate if i were to use it for site work, i bought it for use in the shop and it has never left!
However on reflection i don't think it is actually 3m, I believe it might only be 2.8m as it always feels too short to cut either 4' or 8' with!
Im not sure on the cost basis compared to the Festool... Perhaps if you were buying the Makita plunge saw kit it is, but not buying the track as an add on for my saw it wasn't!
The Festool complete kit is around £500.
DHS680Z - £265 body only (release day when i bought it)
Bought the track set a while later - 2x Tracks £140 + 2x jointing bars £50 + Adapter plate £45 (got the bag free though! woohoo)
£495 total for me (ok thats a seriously bad price
), if i wanted a plunge only saw then yes it would have been much better value going with the Makita kit or even the Festool for the £5 difference!
But i didn't have the requirement for such a specific saw at the time of purchase, with hindsight i should have bought it!
If you have had no issues then i can only assume that it is the adapter plate which has for some reason caused the track to cup!
I quite honestly think that it was a very badly thought out piece with the usual flare of mass producing a 1 size fits all as the booklet for the adapter lists about 12 different models of saw that it adapts!
It would have been much better (for the actual cost of the adapter) to produce a saw specific adapter that clipped directly and rigidly to the base plate of the saw instead of having flimsy metal straps that just fit into the original saw guide slots!
Ok so it might have meant loosing up to 5mm of the max cut depth... But then it's designed for sheet work so why on earth would you be trying to cut a full 57mm with a track setup?
2 sheets of 18mm (36mm) is probably gonna be the most you would want to cut in one go! Personally i probably wouldn't cut more than 2 sheets of 12mm as 2 sheets of 18mm would be a bit rough on a cordless saw!
On a different note, with the whole Brexit thing going on and us really starting to get cosy with our Yankee brethren, looks like we might soon be able to get some real 'built to last' man tools anyway
ccasion5:
