babylon355
Saw a picture of this in an old woodturning mag and thought I'd have a crack.
I used ash with a bit of Chestnut ebonising spray and Padauk.
The ash was sprayed then had a couple of coats of Chestnut Microcrystaline Wax and the Padauk had some sealer on it the given a going through the grades with the Chestnut polishing system.
Total cost £30 for the clock and wood and the usual sanding discs, sealer etc.
The hardest part was getting it all glued up together and keeping it square as my tenons that went into the "feet" were far too loose.
