I would have thought the relative humidity in Sweden was quite high for much of the year, especially around this time of the year. So its surprising that they expect their workbenches to be only used in warmer climes.
Nothing to do with climate - indoor relative humidity is generally much lower than outdoor, unless you are looking at uninsulated unheated sheds, which is what I guess our OP has.I would have thought the relative humidity in Sweden was quite high for much of the year, especially around this time of the year. So its surprising that they expect their workbenches to be only used in warmer climes.
Only in the kitchen and the bathrooms. The overall indoor RH is lower simply because the temperature is higher, assuming a slow to normal rate of air exchange.@Jacob thing you got that the wrong way around for the UK, cooking and people breathing, showering and taking baths, inside the home increases humidity, unless the house has forced ventilation inside will always be more humid than outside.
Temperature higher = higher potential water content = lower relative humidity.Temperature higher = higher water content.
I think you overlook that continental climates tend to have long cold winters when any precipitation tends to fall as snow and does not evaporate leading to low humidity.Temperature higher = higher potential water content = lower relative humidity.
There's a difference between absolute and relative humidity.
Which leads to even lower relative humidity indoors.I think you overlook that continental climates tend to have long cold winters when any precipitation tends to fall as snow and does not evaporate leading to low humidity.
Jim
Exactly, and unlike where Sjoberg benches are made.Which leads to even lower relative humidity indoors.
Beside the point anyway, as our OP lives in warm wet Wales!
Actually the workshop is insulated but is I unheated as it is large (15m x 7m x4m high), heating it would cost a fortune!Nothing to do with climate - indoor relative humidity is generally much lower than outdoor, unless you are looking at uninsulated unheated sheds, which is what I guess our OP has.
If it has windows then solar gain can make a big difference as long as the shed is also reasonably draught proof.Actually the workshop is insulated but is I unheated as it is large (15m x 7m x4m high), heating it would cost a fortune!
