Mr T
For some time I have had an idea for a good beginners bench that can be made using very basic tools such as a DIYer might have. I never got any further with this until someone asked me to make a basic bench for them. I decided this would be a good opportunity to prototype my idea. This bench was 1500mm x 675mm x 910 high. The top is 18mm birch ply reinforced with 150 x 50 redwood underneath. I used 180 x 35 beech for the apron round the top, you could use redwood for this, I used beech because I thought the customer would prefer it. The legs are solid pine while the rails are a box section the whole undercarriage being pulled together by 10mm threaded rod.
I thought I could make the bench using just six tools, however one of those tools would be a power drill with various bits so I’m not sure it can be classed as one tool. I have also not counted the support tool, in making my bench I used a pair of saw horses, I guess most DIYers would have a Workmate or similar.
I started with the under carriage. This consists of legs 95 x 95 with rails made as a box section held together with 10mm threaded rod running from leg to leg. The height of the bench was decided by measuring to the crease of the user’s wrist then adding 25mm. The top is 18mm thick at the legs so this was deducted to get the length of the legs. They were cut to length using a sharp hand saw.
The box section rails were formed using 125 x 25 (rail sides) and 75 x 25 (rail top/bottoms) pse redwood (in effect 120 x 20 and 70 x 20). I made them in lengths so that a long rail ((1245mm) and a short rail (412mm)could be cut from a length, so allowing for cutting etc they were about 1700mm long. As I was limiting the number of tools on the project they were jointed just by gluing and screwing:
- The pieces were cut to length.
- The rail top/bottoms were marked and drilled and counter sunk at approximately 300mm spacings 10mm from the edges.
- 115 x 30 temporary spacers were cut to fit into the void inside the rails. The pieces were sawn then planed to width. The fit was checked by offering the pieces up to the rail top/bottom with the two sides adjacent.
- A test run was done to check the rails will come together correctly
- Next assembly with glue, this was applied to the edges of the sides. The parts were held together by binding with parcel tape then the screws driven home. This overcame the need for clamps.
- When the glue was cured the tape was removed and the sides planed to remove any overhang of the top/bottoms. As the screws were well counter sunk I could also clean up the tops and bottoms also arris the corners. The spacers were knocked out using the threaded rod which will be used for fixing later.
- The rails were then cut to length using a hand saw. It is essential that the ends are square so it’s worth doing some practice cuts first (making the rails a few inches over length will give you some practice space). If the cut is not square some cleaning up with a plane may be needed. I did couple of practice cuts in the waste to get my eye in, this is partly why I made the rails over length.
The next step is to locate and fix the rails to the legs more on that next.
