syntec4
Hello all. I decided with the help of SWMBO that we needed a small table, AKA a side table. I used up some bits of mahogany that I had left. They were originaly the shelves from Salford University Library They did a refurb a couple of years ago and replaced everything with with grey metal racks. My sister works there and told my Dad. He sometimes does a bit of woodwork and so he thought he would have a few pieces that were going on the bonfire! :shock: I was not into woodwork then and didn't even know about it, he said that he could have filled a 40ft container with the stuff but he could not see a need for it!!! . if only I had known....
Anyway the few pieces that he but in the back of his car I turned into this. Hopefuly I have picked up a few things and for the 5th thing I have produced I am fairly pleased with it. Its nice to be working with hardwood.
First I glued 3 pieces of the shelves together with biscuits and PVA
Then I added some strips to the end grain with double width biscuits (No glue) and screws at each end to allow for expansion.
Then I removed all the old varnish with a ROS working through 80, 120, 180, 220 grit paper.
Then I routed a bit of an edge all the way round the top.
Bit of a chunk came out when routing :evil: Will have to be filled with a piece.
Next up was the legs/base. I cut out all the legs in one go with 4 pieces stuck together with carpet tape using the bandsaw.
Made a lot of Orange dust in the workshop. I was wearing a mask, but I think I need some better extraction for routing.
Cut my first tenons by hand. I cut of the top part of the tenon to give the cross rails a bit more strength. I dont know what this is called.
Not a bad fit for a first attempt
The mortises, I drilled then chiseled them square.
I had some help in the workshop
Starting the glue up. I did it upside down so that I could use the bench as the square to work from. I used the just installed bench dogs to help with the clamping.
A few coats of Danish Oil
Leave it to dry for a few days...
And its all done!
If you are not asleep already there are some mor pictures on my website below
Thanks for looking.
Lee.
And its all done!
Thanks for looking.
Lee.
