OPJ
Hi guys,
At college, I've almost finished an arm chair made from English ash with an English walnut seat. Here's a photo from several weeks ago, with most of the components dry-fitted (no finish), without the arms:
You should be able to see there's a lot of curved work involved and, where a lot of the heartwood was split in the 26in wide (!!! :shock
2in boards that I bought, I've had to use some of the lighter wood (not sap! :wink
and have tried to make a running theme/feature of it.
Although it's not clear in this next photo, the stretcher rails are the same; the two outer rails are lighter than the middle one, which was cut from heartwood. These have since been fixed together with wedged through tenons and all components have been given a coat of oil, ready for assembly (well, I still need to carve the seat!).
I ended up buying two of those monster ash boards; each about 10ft long. As you can imagine, I have "some" wood left over!!
:wink: I'm planning to make a kind of side table to go with it; made in a similar style to this chair.
Here's my initial concept, knocked up very quickly in SketchUp:
I decided that several narrow slats looks better than a few wider ones. It's looking quite Arts & Crafts, at the moment.
I think the basic design and proportions aren't too bad though, I'm sure a little refinement wouldn't hurt in a few areas. I'm also playing around with ideas for the top, which I feel should be more interesting than a "boring" slab of ash. I don't have much walnut left and I came up with this idea, which echoes the design of the stretcher rails:
Now I have the right bandsaw, I could easily slice up my leftover walnut and make it as a veneered MDF panel! That would also eliminate and movement issues (I think I just have enough to do it like this). :wink:
The only refinement I've made so far to the design is to add another rail below the top. Perhaps it should as wider as the others or, I should reduce the radius of the curve? Actually, I think those upper rails are a bit wider than they need to be.
No doubt, I'll have to repeat the "two tone" theme all over this table. Trouble is, I don't have a lot of usable heartwood left, which may mean I have to stain some of the lighter wood to match...![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What does the forum think?
I'd like to get the design sorted this month so I can build it in June, ready for July.
Thanks for looking,
Olly.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![4567719168_1eb6793c92.jpg](https://proxy.imagearchive.com/5dc/5dcb2ba74712e4967fda3f843fb746ad.jpg)
![4466957299_436d37f94b.jpg](https://proxy.imagearchive.com/438/4381fb1b6883cb99de6dc96a44b9d70a.jpg)
![4609004773_2442371612.jpg](https://proxy.imagearchive.com/bbb/bbb5d9de2866886c6e7481799c98ddf4.jpg)
![4609005021_2140690938.jpg](https://proxy.imagearchive.com/28d/28d3a02c153bef7270570f3a6778a167.jpg)
![4609612756_fbe3c68427.jpg](https://proxy.imagearchive.com/fa0/fa09ce667366af090e2698158847a1d6.jpg)
![4614765996_f8d8b8b204.jpg](https://proxy.imagearchive.com/c29/c294c394b01c309f37316e85b761c318.jpg)
Thanks for looking,
Olly.
