Hi all,
I recently designed and installed some understairs storage which features 2 x pull out drawers. The drawer carcasses are roughly 450mm W x 600mm D with 1 being approx 1200mm H x 450mm W and the other 600mm H x 450mm W. Both drawer carcasses have a drawer front attached which sits against the face of the angled carcass. The fronts are 22mm MRMDF as they both have intergrated handles routered into them. The drawer carcasses are 18mm melamine MDF and everything has been screwed, glued and domino'd.
The problem I am having is the larger of the 2 drawer carcasses seems to lean forward by 2mm at the top, which can catch your eye as all of my filler panels and other drawers/doors are all in line. I am not sure why it is tilting forward as the runners are rated up to 80kg and the drawer carcass sat perfectly flush if not slightly back from the front of the angled carcass prior to installing and adding the drawer fronts. I understand the drawer would tilt forward as it's front heavy due to the drawer front being attached, but you've got to expect when the client begins using it they're not going to stack items to maintain a balance.
The runners have all of the appropiate fixings in place and the bulk of the runner is sat directly onto the base of the angled carcass so there is no way it is moving up or down. The runners which go on to the drawer carcasses are fixed in every slot with the correct size screws. The runners operate smoothly and the carcasses are sat level. The smaller drawer carcass operates perfectly and all of my margins are correct it's just leaning slightly.
I have packed the runners off the base slightly in an attempt to reduce any sagging/tilt but it doesn't have much effect.
Would adding a 3rd runner at the top of the angled carcass help and prevent this or are the runners struggling? - They shouldn't as I am nowhere near the weight limit, nor have I made a massive drawer its very small in comparison to many understairs storage systems.
I've added a photo for reference. - You can see the opening and how the drawers look before the fronts were attached. You can also see how i've planned my drawer carcasses to minimize the weight by using supporting panels rather than large whole panels and I have hidden my runners by mounting them on the inside rather than on the outside. They still operate the same, you just create an L section on the base of the carcass.
I know side mounted runners aren't great as i've always found them to have abit more play in them compared to some other systems such as Tandem/Movento. I often only use Blum runners for drawers but obviously given the size and weight, it wasn't an option here.
If someone is able to shed some light on why it's happeneing, would appreciate it.
Thanks.
Thanks.
