Side board
MattRoberts
16 Apr 2016
East Grinstead
So my wife and I were fed up of staring at the god-awful IKEA side board that we had under the TV:
y3mUXmosDQZl_I9RhreVWuXrmhGpQkqLqaxyQuGROtB0QJWV7zIOboPJd5Nb0F1hhM3HKtW0iVCxeoppIX3oA8RFbsoM_nifPxymVq1-Tov0GlKcYfLpdEvoOhX4ebeKUYuO9TdXzTDQ0eGZV9dxzF3POV8BV9NDWa4VWhQ0qqERJA
We wanted something similar in size but nicer and sturdier. After designing it in Sketchup, I set to work. First thing to do was glue up a bunch of panels. I'm using Greenheart with pine:
y3mhVQnL7uijBxxutbAHpaSOrsG1tyawxIAzumAwoJdGqSIQDEtg1ZMgav91XtBqrry45kH-UIEkO-6CXwzceXXZ5P5_opc7qJViJiedsXAppGo90TtmVt9hxanCQ6Xu7FtF5miAPXXW6Gez_m1OA5mXZx7TDf0T2AZB2zM_vNQFr8
Next was to dry fit the central section which will have sliding panel doors:
y3mG4Y4q0seoyyvrVcOCRzCbQumYa1SgzoeiGOmAHbSExzweh1TdNhnPm4abg2PiUhxr5nRRQTDnm3kuHFPZV6GzaLH3QRLXAnZjRFY759aZo0D1HTm1hROJqoY-XpE_DAly83xzwbH15rSrzTgd926w6yk4VbOp37PvOXUUplRgkw
I could then cut the legs, taper them and notch out parts to fit the central section and the rails:
y3mORajGch2SM3zJGk9MRvb4-8sK7Wm32I0KRtAKrZPb1WHK8kSHNb69D-vGKWRxip9dFPHZ7RI87ksP-3BZfI4FJGHIofZin2NgF2QTartkrol3kfmLMh1ULD61z6tLnKWtGbftV749si1jepqRUO7790FCPz1JJ_RzQG9DMM5SqM
I also had to notch out the top and bottom panels of the central section to receive the legs:
y3mTl-pSNExeE2GkoS-087AX2ENyn3kLBhRWt3kjBuBuEASGNy87RNVAWc-c-ehVFMa-Ugh0R1qQzoaf4Tf3QvD_u0MFD8bdJmQrxxjo0aY0_LvHkTGAJKsE7X5rJj91j3UecTgsLDrb59NrIqMLxxRbQuhNj12xGuNv8Xrb2gCoCw
Here's a dry fit of the legs on the central section, with one of the rails at the back:
y3mmakqNE-MswWXHEebwdWy801fsT0U0MJ7x12huZn2cCqvzD5wx7udmIGPcLr2Bv0dFi-2t_aE_7Q_v2GaM_SzPZMw_alLK5PARSo-vO5063ELCchu8oIzDFXhqpae4Vcl3mJL0Vnq2h2KCWsV0xTFFiRzLZX8jB0wbGtQZXICzHA
Here's all of the rails. I'm also adding cross bars either side of the centre for structural support and to support the top
y3mLBvjdaY4sErwRA0AW0pX_14WHMLdk6xOx6HHv77IoCltSCx3eBhCfQtesfU__qOmWC-gN0UnBRky11nHKcEV7dgQBx-tr9qmxhWU_pkpKDHZkrG1fLn1xVtfQGj7_ICtHIHnJjO6qvr3Bu8OWmf7b5NL3zH_S1mJRbmlb1nIVYA
Next part was the sliding panel doors. I was given a large oak kitchen cupboard door, so I resawed it quite thin and then edge glued the panels
y3m-vrmPwg8hms9NJgrCqIBOFyeySZUjRumdMwMjkdvuyxyeVu4OXI2BHAyy1fudsVyBzVJggXfD2PXFh28ir5Z3qYGedxwLpZB6eKrh6J-TX1zQkTWLKJ0XZYsZAu5sMRHzkP8fRgLWcTr_xNz5FdgYhiHv-jQ30NuO5yYJJGMPrE
Inevitably, the panels wanted to cup, so I kept them flat all the time I wasn't using them
y3mACMowb_0uEtFF992QvW7bVJhb54Gdq_DT4LXh8LNwRPn08p0vnjYlmmayGEyzY-vapmRQxAzyHTuCIg1o0FYsesG2bizgqyKmv4L84C7cK704P9e119mOXI1LIVUS_WsxHCtLnq5yeJOXljABMKeFjp2jzRK6XR-73MRVOdQEOg
I cut a very slight rebate on the top and bottom edge of the oak panels, and then cut two parallel grooves using a router into the top and bottom of the central section to receive them. This was my test piece
y3mvL5kdUL0KKRBHycv2fHTtM5vX_is3t3AaUnvbu--Xv8nN3O0_ZNGyE5JsJDXiBFktaB3-4V_muuJXU0TwjGbt-vFALJc1pl2CF1jswrWuI6hydASR5sejbUqFXpA2s1opyfyQjyjkNiyQ2sFxb7Pj7TrPBuwnyof7XgxjijBz04
And here it they are sitting in the bottom panel. Note I stopped the grooves short of the domino mortices
y3mpvnc90vi6nz-fIJDjTRR4NHppFDr8Zpfc-q2_qcbIZHBrTNuCuAAKfqW1qpyurRKyOuA3j-DZ5hHUCyttQwzpqKLmSAmahriJXP23GJCyzQrP-LzQ7MgdHZlFfyHmFai5_jF2n6jB9BtYw5qg3uVpZKfheiuDo7jfvJQa_Xq1Hk
y3mjUtblK0_3fVxioNNr_YGN6toJsASKaq-Apb66DwXWlDm1EOJVslvuzy3wXmyczM2SC14FTyQGKqR_nWaG6A7XmLsqfTUehe6wrPBM5p8_qU57c_b0D2Nffuf_N82Pf_YTxrvnvErOye3C8fpNbRPkJsYE4SqcT6p6B5tqlDDJFc
At this point I was concerned that the panels might cup further and become immovable. If that happened after I glued the piece together, I'd need to smash it to bits to sort them out. I decided to add an additional board which would sit underneath the top panel. That way I could remove it without damaging the rest of the piece. As it happens, I needn't have worried as it runs as smooth as a babies bottom!
y3ml63CKst022eLGSy3iXTW6dRSG1WP90pRxbnc_iWvcxHX8vFmf2swjzMTvvPsT648CCQKo7p0LlSQf6DzSamlylnROKru37gKl067fiOKtLjw3hSV881UZLY6PTxKl6OeTszB0NGGlVONg76GPL9HK6m3AojuzpeipTP9HkxhbgE
This shows one half of the central piece with everything put together. It's actually upside down, so you can see the double thickness at the bottom.
y3mo56771AeBfbBwHQks2pcKFQkmpe46vpAtX2TwiQ44DwSyx6q5uEUcKK9629Ggo-GMdRaj9ww6Dr3jPFgz2lQfVa5dHYxRT2GwPkyCJbyWN6YsFTPwoIdSXPVy2-CelnZuTRjHXilFbofAO0ASgBRKJX40nyh8ZRhXlE-LxHKT6A
I could then glue up some parts of the main central section, thankfully I have a lot of clamps
y3mt28KqOG3r47gBgCVPQucQWK9LDpy8rr7IqxInhVIx5VVwzjrLXBH48EYavrTPvbv81KG9DZEFp3-5tE-MEG28cjiu0sH7n0dY6a4PdBm7QWhbcbBJyE5G-j-8zgZZHbE4h3gZQHvrb4bAJiPgsphRNyAkzwf9WaOfgPaqUxAeZo
The top was glued up in stages to make it easier, and also has dominos to help with alignment and strength
y3mQRHDlkESMOSnz3Dn6e996xC9jLnzHGGUdc709P2Y9Mh_YfKUFiP_gSCsfrnfC26Z4nT26X4ZTbmYo3Qkq6GdeEM4RnMfNfDpM2UyUlu9v7BEIInSCEV-XTckN4BdnVgAN4T1edaXq365WBGu2TQb48XuzrSyUCvKGPw0mkkzj6c
I used Danish oil on the oak panels to highlight the lovely grain. Unfortunately I was limited on wood, so couldn't do much in the way of grain matching. Even though, I think I could have done better if I'd thought about it more.
y3m7BJZlRFjQCKXWpr15YbV_L8XM_3WGnfc7eNEtcmexIHed9d3oaNnkvxepzB_va-WqkGU3a5EJO0dp23rAj0XWLVm92vlyKKzs6sAZdxBDu7fVObfZ2zXk88r8_x5eYvhkkEXU4yRBIkBhjcL0d8Mcfyz3Oh95DG1wLruNND-Ppc
I finished the rest with walnut Briwax
y3m7acaA29bwK5vgR8qQgGp5Z73_oJzHqg9-tQImcShAvkAYoQP4m4TI5IkkAPu-hWEnzrRKHaLSusFZl72AjifhzeE4csThsHTwk7dkcIGfewExucSdtIK4n0Egxo_2bJmLdRu5K1MHFhNkiXYDpvoyYM2IdHiCbCiCCQiKr-QhmA
I cut some handles from the same Greenheart
y3maP851KZuw91DuTTznAqFT8IVfdgpy4QhexWP2TTUzK6ATCHgSuDBB3La3-0xey3gdkXpX9mdFZdOS0X-8eFOcqkxRSBbmorSpXy_Ji-HpTpFM7oDDB1kDwWhhrCCbBY6cYc3qVTqjiFg0u9ZOjn1I39Rnq7rQPd3bLf1PadL97k
So I did the main glue up after the finish was applied. I'm in two minds as to whether it's better to pre-finish or not. On the plus side, it's easier to apply the finish and you don't get clumps of finish in the corners. On the down side, you have to be careful to get as little finish on the areas to be joined and in the mortices, which is a pain. Additonally, cleaning up the glue can mess with the finish a little bit, especially if it's wax.
y3mz4c4S4xlTBNc-zLbEdhwtiSyvIIRww2ef1qcjT_1vvrqqYWzxxTALaBPdXtsGlHe39g3qVMdYiED-0oeK5d99hrjMaC-Fyj-c1QZ1vse8qyX3XbV4vj7hLikvv_EpQ9BF0525VFeNTWNU88z6gzb501-VuTtb4AmObcE5-TnAUI
On go the rails and legs
y3my7YpO725AmDRA8Ng9haJSrm29uj5dHASVS48qXKA_zM6mdu8WBpPu2VHQLHR_L2XJlKzNR-KpJctpPUa-6vSPLldGqMg1pBCtKw86AJQPtU-DS6f77wihakahQc4KX2ksOezD3jrp1g8tofMZseOh6sgjD8DAR1fPGQVB2V1Yro
And here's the finished article
y3mnbvVgpHiA2dYEj7iYHe6U4lzYSPFvZCkAIMzExlNM02PWIH3xOH32VYAvGElv8TMWJS0NGbo0x06baIcY-pLz1gNM2OuXxwuJ_bTlzkks3V9YIvl6PxSLHW2b7dqRRRslQlyRTYOD1nABYTgRC6veap-bomXAnDQ6C9L1dv44tQ
And in-situ:
y3mghcdxDlu0oLcCr2HNz9VibwLLEDnFXsvFoR_bTu9mHSZOD39OPcMA5pzrq5e0pmIVn9LBb528Akpzpis1KMV_7R2fdY22oAMnsLFnW9TU3RZ7aFFrwp5i6JTX1Q1Zc9v8v8Q2HkJIUPU9M3EdTJWNBsIl1EYHku9cCZFezQfJ6A
That looks a lot better than the Ikea unit!
You can make removable panels by having a deeper top grove so you can lift the panel and swing out the bottom.
Thank you. I wish I'd done that now, but the top and bottom parts of the centre section are only 20mm thick, and I was concerned about having a deep enough groove to keep the oak panels flat. In hind sight, I didn't need to worry so much :)
Looks great Matt, I like the style you've designed.
It's so satisfying when you can replace the 'make do' furniture with your own bespoke designed pieces.
I'm still working on refurbishing my house but I'm already designing the first pieces ready for when I can make them
