The reason you should get a drill that hs a low speed (lower than 650 rpm) is to avoid burning up your drill bits. 650 is ok on wood but will murder bits on steel, even with lubrication.
The point I made about T slots refers to the slots seen in the table. These are cut-outs where a T nut can be slid into these slots, allowing it to slide along the slot but locking it in when upwards pressure is applied to the clamp. These slots allow you to fix vices and cvarious clamping set-ups onto the table. You can see these slots in a post I did about a drill refurb:
http://wanderingaxeman.blogspot.no/2012/07/ixion-bst-13-refurb.html
My advice is to buy used. Modern tools don't match the quality and longevity of old school. Tools. Remember with these old tools you pay for bearing quality, mass and build quality. Modern tools may often be cheaper but this comes at a cost to quality and therefore longevity.
Paul.
Paul.
