kinsella
Colleagues
I decided to build a wooden box for my Beretta over and under. The box will be posher than the shotgun. Can't seem to find any WIP's for a shotgun box so thought i'd share. i had some old antique oak. The oak had original animal glue joints, so i cut these out and re-glued the boards back together. I had intended to use 18mm oak but when i put them together they weighed a bit so i planed down to 12mm and this was more manageable.
The joints are finger joints using my box cutting jig. See link here for how it was built.
box-joint-jig-sketchup-plans-free-of-charge-t87240-60.html
Image of box
Old Oak
Looks good cleaned up
Using box making jig to cut the fingers
Fingers cut
Glued top to sides
Glues bottom to sides
Starting to work on corner protectors. Making them from scratch and will silver solder all the bits back together.
The ironmongery hinges will be Brusso hinges.
Can anyone recommend catches for the front?? The stuff on Ebay seems to be either pressed metal or gold plated stuff. I want solid brass. i was looking at the attached from "Jewellery Box Hardware" http://www.jewelleryboxhardware.com/Sli ... ***-Finish. But not sure if these are sufficient for a heavy type box. Any better ideas?
I intend to build the handle, corner protectors etc from scratch and will post WIP pictures as i go.
Image of box
Old Oak
Fingers cut
Glued top to sides
