jimi43
Some people simply collect old tools and around here the term "collector" causes people to run away.
I guess I could be called a "collector" if the number of planes I seem to have acquired, mostly at bootfairs...is totted up.
This Christmas I was lucky enough to receive a lovely present in the shape of a mini shooting board cum bench hook and was keen to try it out.
I have two suitable mitre planes and one is pretty boutique but my old Spiers was in need of a test on a board (to my shame I hadn't made one for it!) and so it was the weapon of choice!!
When I found this old gem at the bottom of a box in a bootfair and rescued it for the princely sum of a couple of quid...I had to make an iron for it along with a bit of lever cap restoration and this was one of the first irons I had made. I knew it performed well as a smoother.....
...so I had an idea it would make a good shooting mitre plane.
On this multi-function board there is a step down as in a shooting board as can be seen so I wanted to try it out on some small stock I had...first some mahogany...
...and I was treated to that wonderful whooshing sound you get when you know it is all going right!
Quite how right can be seen from these microscope specimens!!!
They are cellular thin....
...and remember this is END GRAIN!! :shock:
Ok...let's hit some beech. As with any good fence...the end is made slightly over so that the first passes will take it to the correct level and the slices of beech coming off the end were super thin....
So am I pleased with my new toy used with a very old toy? Of course I am....
I think this combination is going to get a lot of workout pretty soon!
So next time you are at a bootfair...check out deep into those cardboard boxes low down under the stalls...you never know when something is going to pop out and have a new life all over again!
Oh....and a note to obsessive collectors...this one is for use...get your own for your dusty shelves and investments! :wink:
Jimi
Jimi
