Paul Chapman
I've just made myself another shooting board. Previously, I've always screwed on the planing stop but having seen how Rob (Woodbloke) makes his with a wedge, I thought his method had some advantages.
Here's the finished shooting board
[/url][/img]
The board is made from MDF, with the baseboard lipped in softwood and the wedge made from a piece of scrap mahogany-type wood. The wedge has a slope of about 5 degrees, which seems to be a good slope to ensure it won't come out accidentally but can be easily removed with a sharp tap from a mallet.
You may also notice a piece of MDF behind the wedge. I routed a slot in the MDF exactly at 90 degrees to the edge then placed the wedge against the straight edge and used that to guide my router in order to get the other side of the slot at the correct angle. That's where the senior moment occurred :roll: The slot, of course, ended up wider than the wedge by the width of the cutter. I should have moved the straight edge down by the width of the cutter. Rather than cut another wedge, I glued in a piece of MDF, banging in the wedge, waxed to ensure it didn't get glued in, to hold it all firm.
[/url][/img]
Having finished the board and tried it out, my senior moment seems to have been a good thing, because the additional piece of MDF provides a very good and firm support for the wedge, which can take quite a bashing from planing end grain.
The advantage of using a wedge rather than a screwed on stop is that if the end gets at all damaged, it can be knocked out, a shaving or two taken from the sloping side, and replaced.
Cheers :wink:
Paul
Cheers :wink:
Paul
