Derek Cohen (Perth Oz)
Hi BB
I was about to use the #51/52 today when I had this idea to compare it with my ramped shooting board, both using the #51. I thought that this would throw some light on the effect of a ramp in shooting end grain.
One of the observations I have posted before, in comparing a ramped with a flat shooting board, was that the ramped board appeared to reduced the impact shock of the plane. The slight skew imparted by the ramped board is too low to be compared with the skewed blade of a #51 shooting board plane, but it was enough to enable the blade to enter the wood with a slight slicing action, and that this was significant.
You suggested that I try the #51 on the ramped board. I thought about this today. Would the skew of the #51 neutralise the influence of the ramp?
First I compared the ramped board with the #52 Chute Board, both using the #51, on Jarrah end grain. Here is the ramped board ...
A close up of the shavings ...
Then I repeated this on the #52 ...
I also used Radiata Pine ('orrible stuff) on both boards ...
I went back-and-forth several times.
My impression was that the #51 on the ramped board felt smoother than the #51 on the #52 chute board. Both boards produced excellent surfaces. The difference was simply that the ramped board jarred less than the flat #52.
Regards from Perth
Derek
Regards from Perth
Derek
